6ofus,
I'll address one of your points regarding safety. "A’s do not have air bags."
That's because they don't need them. The purpose of an airbag is to slow the impact of the human with whatever is coming up to hit them inside the vehicle. The more mass the vehicle your driving has, the slower this process will occur. In a passenger vehicle, you are very close to the windshield and A pillars of the vehicle. Very close. In order to minimize the impact, the airbags deploy. However, once they deploy, FORGET about having any control over your vehicle. You just had an explosion in your face.
On a Class A, as was pointed out, first of all you're probably 4-5 times more massive than the vehicle that's likely to hit you. If both vehicles are travelling 50 mph in opposite directions before the collision, immediately after the collision, your vehicle will be slowed to about 30 mph (going in the same direction) and the passenger car will now be going 30 mph (in the OPPOSITE direction of their travel). That is, your vehicle slowed a bit, in that same time, the passenger vehicle came to a stop and is now going the 30 mph the opposite way. (OK...I'm making a lot of assumptions & approximations about the vehicles and the collision, but mostly the numbers are indicative of the outcome.) A bit graphic here, but understand that there are 3 collisions that occur. The vehicles collide, the bodies inside collide with the interior of the vehicle, and then the internal organs collide with skeletal system. Since their vehicle went through that rapid deceleration/stop/reversal, the bodies inside are getting bashed around as first their bodies have to change direction and then their internal organs have to change direction. Nasty. Sorry to be so graphic.
Also, in the Class A you're up above them. In other words, in a front end collision, one of your main chassis beams will be just about at the passenger car drivers head level. Their roof might hit your vehicle where your feet are. Your head is safe from the impact. Since your vehicle is not subject to the same rapid deceleration and reversal of the other vehicle, there's no need for an airbag. Also, AFTER the collision, you're vehicle is still travelling at 30 mph, you want to be able to control it. You DO NOT want to have an airbag explode in your face and then the next second try to control the vehicle. In a passenger vehicle, the airbag is really there as a last defense with the expectation that the vehicle will be stopped after the collision and not require operator control.
THAT is why airbags are not included, nor wanted, on a Class A motorhome.
The bottom line though, is that in a collision, mass is your friend. Drive safe, make sure passengers are belted during most travel, be alert, watch for the other guy and you'll be fine. I feel MUCH safer driving our motorhome than any passenger vehicle. It's good to be the king! LOL :)
Remember that posting in the class A Forum you'll most likely get a preponderance of "Pro-A" posts. In the Class C Forum you'll most likely get a majority of "pro-C" posts. But that's OK. You're getting real world experience from those of us who have "been there, done that". Keep the questions coming.
Good Luck,
~Rick
