struluv
Mar 01, 2013Explorer
Newbie driver
Does anyone have any tips on driving a 36' MOTORHOME? What about a driving school? Any help would be greatly appreciated. Thank you.
frankdamp wrote:This is very dependent on the "degree of wheel cut" of the steering axle. Some coaches have a 45 degree wheel cut while others have a 50 degree or higher. If your coach has a 45 degree wheel cut, your front bumper determines when to start the turn, while if your coach has a 50 degree or higher wheel cut, you use your hips to determine when to start turning. Barney Alexander explains this really well in his video, Part 5: Turning in Your Motorhome.
The tip I learned with the transit coaches, that has paid off very well now we have a 32' MH, is positioning for a turn. It's a similar trick whether turning left or right. You go straight ahead into the road you're turning into until the curb (right turn) or lane divider (left turn) is directly in line with your shoulder when you turn your head, then you crank the wheel over as quickly as possible, straightening up when you're in the new street. For a 40' rig, go about another 4' past that "over the shoulder" point.
