Ivylog
May 09, 2013Explorer III
Even if you spend full time on this from Branson, you'll be lucky to find the right DP in the next 30 days with your requirements. Other than Alfa I would not worry about the brand as each make entry level MHs and many make high end MHs. At that old and winter use you need high end. Even at $60K you'll be in the 95-98 years with maybe one slide. I would not worry about floor plan as in those years they are all about the same if they are front entry. You need double pain windows, a 10K hitch, 40', a Onan quite diesel generator, and AquaHot if possible. Good luck as in a year you'll probably be trading which costs $$$$ if you rush into this.
38,782 PostsLatest Activity: Sep 01, 2026
