Executive45
Nov 09, 2014Explorer III
First off, post as much info about YOUR rig...make, model, year etc. That will help a lot. Second, look under the dash and see if all the wires going to the IGNITION switch are pushed in solidly. Sounds like you have a loose ground wire somewhere and with the coach not shutting off, I'd start with the ignition switch....good luck...Dennis
38,707 PostsLatest Activity: Feb 18, 2025
