CharlesinGA
Apr 19, 2018Explorer
You don't "chip" a Sprinter. One company, Green Diesel Engineering, has engineered new software for the Sprinter's computer and a method for you to load it in the computer, and retain the original software. It adds some performance, but not a whole lot, more reliability than anything (no personal experience, but from what I have read on the Sprinter forum, and the View/navion forum.
Remember, you bought a motorhome with an engine half the size of one in other Class C's and carrying essentially the same weight, you cannot expect it to do more than what it does, get you efficiently from point A to B in comfort and reliability.
Mercedes is extremely picky about fluids and lubricants and for the sake of the exhaust filter system you need to stick with the oil specs in particular. You will not find the oil you need at Wal-Mart or many auto parts places. NAPA carries the proper spec Mobil I and Valvoline oils and many times has it on sale.
This Bevo page here lists all current MB specifications. Use your owners manual to find the proper specs and click on the spec number on this page and it will link to the list of approved lubricants and fluids for that spec..
http://bevo.mercedes-benz.com/bevolistenmain.php?language_id=1
Sheet 223.2 lists all engine oil specs for various motors. In your case you have a diesel engine - worldwide - w/particulate filter - van engines - OM642 (you find the engine model on the sticker on the valve cover) and this is the next to the bottom line on the first page of this PDF.........
http://bevo.mercedes-benz.com/downloadf.php?filename=en/Spec_223_2.pdf
Follow across the page and you find your approved oils are 228.51/229.31/229.51/229.52
The 229.52 spec is more for fuel savings (as opposed to the 229.51 spec) and thus does not approve any 40 wt oil for this engine.
Go back to the first link I posted and click on the 229.51 link and it will give you this page.........
http://bevo.mercedes-benz.com/bevolistenmain.php?navigation_path=bevolisten&blatt=229.51&content_action=show and it will give you a list of oils world wide that are approved to this spec, with footnotes you need to pay attention to.
Easiest oils to find in the US for your engine are the Mobil 1 ESP 0W-40, and the Mobil 1 ESP Formula M 5W-40 and the Valvoline MST 5-40 oils.
Using non approved oils will cause you grief as they will clog the exhaust filter.
Transmission fluid, only a couple are readily available in the US, the OEM MB fluid, Fuchs 4134, and Shell ATF 134. The Shell is stocked by many Distributors and using the Shell Distributor locator and calling them will find what you are looking for.
The oil filter cap is plastic, get the proper socket (the aluminum ones work better than the stamped one, and use a torque wrench to reinstall them, 25 nm/220 lb-in/ 18.4 lb-ft of torque as they are easily damaged if over torqued.
Buy you a Fumoto oil drain valve, either a F106 or a F106N (has a nipple for a hose) and your oil changes will be fast and easy and no mess.
http://www.fumotousa.com/results.php?make=57&year=2014&model=28072&makeid=MERCEDES-BENZ&modelid=SPRINTER+3500+3.0L+V6+DIESEL+TURBO
Wheel speed sensors in the 2014/2015 vintage CHASSIS (chassis is usually one year older than the coach) are prone to failure and are covered under the EMMISSIONS warranty which is, if I recall 5yr/50K mi. failure of a wheel speed sensor, esp a right rear, will cause the vehicle to go into limp mode as this provides output speed sensing for the transmission and without this speed sensing the transmission cannot determine what gear it is in.
The Sprinter is quite reliable until it breaks, then it is a real devil to fix if you don't understand it. I highly suggest you join the Sprinter Forum and if there is a forum for Sprinter/Forester, join it too.
Charles
Charles
