rbago2
May 30, 2018Explorer
Had same problem with my 2003 Suncruiser with the Workhorse 8.1. The malfunctioning ABS caused the torque converter to in and out of lock causing the RPM to change up and down with no change in speed. Solution was just to clean the ABS sensors in my case or could you may have a bad sensor or bad ABS module.
