Pirate1ExplorerJan 07, 2019No 02 Downstream Sensor 2006 F-53Ford says there should be one in the cat. I have a top plug in the cat, no sensor. No wires anywhere near the area to indicate someone disconnected and removed. Any ideas?
allbrandautoExplorerJan 07, 2019do you a check engine light on with a code for down stream o2 sensor if not you don't have one
Related ContentQuapaw Oklahoma Downstream CasinoMopkka tank SensorsSensitive headlight sensorDometic fridge RM2652 tripping thermal sensorTemperature sender/sensor... 7.3L
