4x4van
May 30, 2016Explorer III
dtucker3usa wrote:TNGW1500SE wrote:dtucker3usa wrote:
I have sort of the same problem except that unless I'm hooked to shore power or running the generator the only 12 volt I have is to my steps. all other 12 volt systems shut off as soon as you shut down the generator or unhook from shore power. Also the coach batteries are relatively new. Any suggestions? I have a 1997 Damon Intruder with two 12 volt coach batteries.
Is there a main switch? It would be located just inside the door.
the three switches by the door go to the step, porch light, and dome light. There is no battery disconnect switch there.
There IS a main battery disconnect switch somewhere.
