CharlesinGA
May 31, 2016Explorer
dtucker3usa wrote:
I have sort of the same problem except that unless I'm hooked to shore power or running the generator the only 12 volt I have is to my steps. all other 12 volt systems shut off as soon as you shut down the generator or unhook from shore power. Also the coach batteries are relatively new. Any suggestions? I have a 1997 Damon Intruder with two 12 volt coach batteries.
Most likely the steps are powered by the chassis battery. That is how my C class WBO View is set up. They design it so if you get the engine started, the steps can be retracted even if the house batteries are dead.
Charles
