prstlkExplorerJan 13, 2016NO 12 VoltTrying to help out a fellow RVer. Has a 2004 ish HR Ambassador , no 12V at all, lights, furnace, water heater nada. I have an 07 but they are very different. Checked pedestal, inverter, turned both of...Show More
rgatijnet1Explorer IIIJan 13, 2016When you by-pass the 12 volt switch relay, make sure that you jumper the right two contacts and not the contacts that activate the relay.
Related Content12 volt only refrigerator12 Volt Power IssueNo 12 Volt without converter12 volt issue?12 volt fridges
