enblethen
Oct 26, 2017Nomad
Plugged into shore power the converter or inverter/charger would be supplying 12 volts DC to the rig.
If not connected to shore power the interior would be getting power via the battery if charged.
With the chassis engine running the rig should be powered off the alternator.
See if you can locate the converter or inverter/charge and post make and model.
Sounds like the main fuse/circuit breaker in 12 volt DC distribution panel is blown.
The battery control center is not connected when on shore power. It is used to connect 12 volt systems together and for supplying 12 volts DC to manufacturer's added systems
