jswat wrote:
I am connected through a portable Progressive surge protector which shows correct wiring and 50 amps. Everything works inside the MH but I cannot run both a/c units unless I turn off something (like the water heater). The transfer switch has no problem switching between genset and shore power. Something is just not letting 50 amps through.
The question remains..... do you have 240VAC across the two 50A hot leads on the pedestal??? It is a simple measurement with your VOM....please report. It is unknown, to me at least, if the Progressive protector would give an error condition to same phase voltage across those two points so it's showing of "correct" 50A service is inconclusive.
