Gjac
Jun 10, 2015Explorer III
If you are charging when plugged in and not while driving(if I understand your post) then I would suspect a bad solenoid. Check voltage on either side(2 large wires) to see if contacts are burned. You should have 14 v on either side with engine running and 14 v at battery if all is well.
38,766 PostsLatest Activity: Jan 10, 2026
