Lobstah
May 20, 2013Explorer
The 12VDC circuit usually powers things like control panels, etc. If you lost 12VDC, you wouldn't have power to the control panel.
If you had NO 12VDC, I'd suspect the charging circuit. That will usually put out 13.5vdc even if the batts are bad.
Put a meter on the batts while plugged in and see what you get. Many times, if the batts go bad, the converter/charger isn't far behind because it gets overworked trying to charge batts that can't be charged.
Jim
Jim
38,763 PostsLatest Activity: Jul 22, 2018
