VA-Apraisr's avatar
VA-Apraisr
Explorer II
May 31, 2017
No fuel for generator......line to gas tank?
Onan generator would run then cut off. Pulled fuel line to carburetor off and hit start button but no fuel coming out. Put it in shop and they said it would suck gas in from a can and run but wasn't getting gas from coach tank. Suspect maybe a cracked feed line from the tank? Do you know if we have to replace an entire gas line back to the coach tank, or is there a Y-connection somewhere after the inline fuel filter? Just trying NOT to get ripped off with potential hourly charges. Thanks for any input.
  • X2 most rv,s have a shut down for the gen set at 1/4th tank . if it ran on there test can I,d put fuel in the rv and retry. p.s auto gas gauges are not perfect.
  • Generator has it's own feed from the tank and it's not on the bottom. Generator will stop sucking gas at about 1/4 tank or maybe a little more.
