chast's avatar
chast
Explorer II
Apr 20, 2016
No go water heater
Hi--new to us '97 RT170. De-winterized, fill water tank, pumped up. Started water heater (DSI). Red light came on, burner fired up and I though I was good to go. Let is burn for a while but when I went to enjoy some hot water--no go. Re-set the switch and waited--nothing.
Checked connections. Circuit board which is mounted inside cabinet where water heater is located seemed to be warm. Pulled connection on board and re-attached. Can get nothing from the system. Do I replace the board? Thanks for your help.
  • Problem solved! Thanks all! As usual I thought I knew what I was doing but that wasn't the case. As soon as I checked for water at the pressure relief valve and got none, I knew I had the bypass valve for the water heater in the wrong position. Corrected my position and all is well. Thanks so much to all who chimed in!
  • Sounds like you have dry fired the water heater
    Sounds like you also have a Suburban Water Heater (circuit board inside cabinet)
    Fortunately you dry fired using propane (Started water heater (DSI). Red light came on, burner fired up)
    NOW hopefully you have waited until tank has cooled down before allowing cold water into WH TANK.......(Steel tank GLASS LINED!!!!!)
    Once cooled and you have changed valving from 'winterize' to 'normal' and tank has filled---------reset the High Temp T-stat
    Outside compartment above gas valve 'Push to Reset' buttons
    Left one is to reset the 120V AC (electric)
    Right one is to reset the 12V DC (propane)
  • RoyB's avatar
    RoyB
    Explorer III
    If you have fired up the water heater without water in it the heater element is probably toast now. Some have a thermo kickout so you may be ok...
    Need to check to make sure the heater has cold water in it before firing it up... Easy check is to go pop the hot water relief valve on the back and it should squirt water...
    If no water then the most probably cause is the winterizing valves are in the wrong position..
    This is pictorial for the older setups with three valves like I use here...
    Roy Ken
  • Check the water valves. Ill bet their still in the winterize position
