prism
Oct 15, 2013Explorer
always-ready wrote:
Good Morning,
I'm having a problem with our 2004 Tiffin phaeton 40' motorhome on the freightliner chassis with the cat c-7 engine.
We left for a trip and found that we have no headlights, turn signals or hazard lights. I can not find where the fuses are located. I found a fuse block under the center drawer that was marked turn signal power, and in the right rear baggage compartment that is marked left and right turn signal. Both fuses are good. I checked the main electrical cabinets, one is on the outside under the drivers seat and the other one under the bed room tv. Out of the four places that I have looked, I have not found anywhere that says headlights. Does anyone have any other ideas of where I could look?Although I cant beleive they would run the signal system through a headlite module but on DPMH chassis wireing system you never know
Thanks,
Eric
checking for fuses in my opinion is a waste of time.The chances that all those fuses blew at the same time is about zero.I would look for a power source failure that most likely supply,s all of these lite systems.The last post indicates a module? that sounds most reasonable
