bomarhe's avatar
bomarhe
no heat from front vents
Hi, I have a 99 Endeavor DP which we recently purchased with a heater/blower problem. In colder weather, say below 50F, I get no or little warm air coming from the vents. After parking at a rest area for a few minutes, it works fine for about the first 15 minutes then progressively slows down to practically no air flow. The blower seems to have only one speed, high(when it works), then slows to a trickle after being on for a while. Even while setting without the engine running, it only has off and high. Sure gets cold in there at about 40 degrees. I'm thinking thermostat for the low heat output and a bad switch for the blower problem. Additionally, the defrost/defog has no air flow at all, makes for an adventure in cold wet weather. Any suggestions from those with experience with a similar problem?
Second question, how does one get rid of a foul smell in the freezer? Had a power failure with stuff in the freezer for about 2 weeks, suggestions?
Thank you in advance for any help.:?
