SCADAMAN29325
Nov 08, 2022Explorer II
Well, that was a little aggravating not having the right tools, but it's done.
Learned that the propane system uses lefthand threads on one end and right hand threads on the other.
The correct size wrench for LP connections is a good set of channel locks.
That no matter what you buy on Amazon, you'll still need to go to the hardware store at least twice, once to buy everything you think you need, and second, to take back what you really didn't need.
And usually I never throw away parts till way after the job is finished, but this time I did. I could have used a fitting, that I thought I already had.
Now on to testing the stove, fridge, water heater and furnace.
The water pump will be in a few days, that will be most of those parts.
TTYL
TTYL
38,782 PostsLatest Activity: Aug 31, 2026
