Ivylog
May 23, 2013Explorer III
Dave, as you stated, you do not have an electronic engine... something pulls on the black lever in the picture I posted above. There is no derating on your engine. How many RPMs do you get and how much boost pressure when you try and go up the hill? If you are getting 1500+ RPMs and 10 psi boost then I'd say your tranny is low on oil and it is slipping. Econo mode raises the shift points, not lowers... but in first gear it makes no difference.
38,782 PostsLatest Activity: Aug 31, 2026
