bluebirdPT36
May 23, 2013Explorer
First I will say that I am not familiar with the throttle on your coach. If it is drive by wire, with the aid of an assistant, can you watch the throttle lever at the injection pump and see if it is going wide open when assistant mashes foot throttle? You may be able to do this with the switch on and the engine not running. If it doesn't move, try test with engine running and trans in neutral. CAUTION; make sure it is in neutral and the assistant is someone you can trust not to do anything stupid.
38,782 PostsLatest Activity: Sep 01, 2026
