JetAonly
May 25, 2013Explorer
havasu wrote:
Have you done a stall test on the transmission?
How many revs does it give you?
I was thinking of this, too. Stall speed is like 900rpm? A drag racer might have a stall speed of 5k to get max HP at launch. The RV is much lower in order to prevent overheating the fluid.
So at 900 rpm you aren't going to build much boost anyway, even with a new gasket.
You simply need to figure out a way to keep some momentum, like keep some speed, or change your drive way.
38,782 PostsLatest Activity: Aug 31, 2026
