j-d
Sep 07, 2015Explorer II
Roger That. So then I concur with everybody else. Problem is 12VDC only. If you had 12VDC control voltage to the thermostat your A/C would also work.
I take it that the large terminal on the left side of the solenoid runs to the "12 Volt Disconnect" and the large terminal on the right leads to Battery Positive. If So...
Battery Connected: Do you have 12VDC between the large terminal on the right side of that solenoid, and Ground?
Battery Disconnected and Shore Tie Unplugged: Do you have Continuity (Zero Ohms) across the two terminals of "12 Volt Reset?"
Where are those 5A fuses? In the circuit of the small "+" and "-" terminals on the solenoid?
