bobndot
May 16, 2023Explorer III
If the switch is on then i would ,
Remove the cables to the battery and check the voltage. 12.6 - 12.8 range would be a fully charged battery.
If there is no 12v power once you replace the cables, i would check the fuses and make sure the ground connection off the neg battery terminal to the chassis ground is clean.
38,782 PostsLatest Activity: Aug 31, 2026
