Gjac
May 24, 2013Explorer III
What voltage readings are you getting at your batteries? Are you getting the same readings at your battery soliniod? Are you getting the same readings at the 12 v fuse panel? The two things I would look at first if you are sure the polarity is correct is the cable connection to the inside of the terminals look for green corrosion or loose terminals. Also I found the set screws at the 12v fuse panel can sometimes loosen and need to be tighten.
38,766 PostsLatest Activity: Jan 10, 2026
