tenbear
May 28, 2013Explorer
y1mespinoza wrote:
I checked all the fuses the only ones that have power are the two 15 amps and the 20 amps. The rest have no power. I did check the all the fuses with a tester and they are all good. But if i plug the RV to power or run the generaror all fuses have power.
My power distribution panel is made so that the power comes to the panel on one wire. The power is then distributed to 9 fuses that are wired to the various house circuits. There are also 2 30A fuses on the panel. It's a Magnetic panel.
Since power is getting to the panel but only some of the fuses are powered up, if your panel is like mine, the problem is on the panel. That's a big "if".
You are going to have to figure out why power is not getting to all the fuses.
38,766 PostsLatest Activity: Jan 10, 2026
