dougrainer
Mar 13, 2020Nomad
Executive wrote:
Doug, that is true. However, in his case, he already has a wire connected to it that has no power...at least while he's not in reverse. That said, in order to connect something else to it, i.e. brakes etc. he will need to reroute the current wire correctly. There are 7 pins and it doesn't matter what order they're in unless someone else is working on your rig. The only reason we use the pins as we do is for conformity if we use a commercial tether or someone else works on our coach. Just clarifying so someone does not get confused.....Dennis
Sorry, IT IS THE ORDER. There is a Standard order of what pins do what, and if someone decides to change, that is not a good idea. ALL 7 way Bargmans will have the exact same Pin connections if installed correctly. Doug
38,769 PostsLatest Activity: Apr 03, 2026
