23hotrodr's avatar
23hotrodr
No power to center pin of 7 pin trailer connector on Winne
I have a 2007 Itasca SunCruiser 35L. There is no power to the center pin of the 7 pin trailer connector, but does have a 14 ga wire connected to that pin. I have never tested this pin previously for power since I did not need it before now. I now would like to have a charge line go to our new dinghy and have everything in the dinghy and cord from the MH set up for this power.
Does anyone know where Winnebago typically picks up the feed for this 12 volt wire to the trailer connector? Fuse? relay? I assume it is meant to be supplied at all times so the engine does not have to be running for power to be transmitted to the center pin of the trailer connector.
If anyone can steer me toward the origin of this 12 volt power via fuse, etc-- I would be very greatful. I have looked at the 2 12 volt fuse panels I know of and have not found it.
Thanks for any help you can offer. I do have the wiring diagrams and such, but they have proven to be more confusing than helpful so far.
Thanks-- Mick
  • Thanks Scottg-- After more looking, I found a breakout of the trailer connector. Yes the center pin is labeled for backup lights. Guess if I want a charge line, I will have to install one.
    Thanks for your help. -- Mick
  • That pin is for backup lights. So it's only hot when in reverse.
