- CharlesinGAExplorerLoose connections in RV's are a real problem, unplug, and shut off generator and then go chasing loose screws in transfer switch, breaker panel, etc.
Charles - 2chiefsRusExplorerso what was the problem? Has it been solved yet?
- LI-CamperExplorerOnce when I had the same trouble as the OP, it turned out the power cord was loose where it connected to the coach in a junction box. The junction box was located at the back of the compartment where the power cord is stored. Apparently, when putting the power cord in and out of the compartment, the wire nuts inside the junction box were loosened. Easy fix.
- ADAD437Explorertransfer switch. had the same problem a few years ago. called and got a new board, simple to replace.
- CruisineasyExplorerI had that happen a while back. The plug to the power converter came loose. Easy fixes are the best!!
- 2chiefsRusExplorerWe had a similar problem years ago and it was just a loose screw in the transfer switch.
- DrewEExplorer IIISometimes a good thump or poking at it after opening it up (obviously with all power removed) can unstick them. It still probably should be replaced as I suspect it's not likely to keep working well for too much longer once it's been stuck once.
Most 30A transfer switches use a single big double-throw double-pole relay/contactor, with some sort of time delay circuit on the switch over to generator power. The shore power is the normally closed circuit, and the generator the normally open one that gets closed after the time delay. Contacts that get too hot (due to wear or arcing) can weld themselves together and keep it from switching back properly, and this is one common source of sticking; to a large extent, this sort of damage can be avoided by not switching under (heavy) load.
Edit: Also check that the connections between the power cord inlet and the transfer switch haven't worked loose. It may be as simple as a screw that needs tightening or a wire nut that needs re-nutting. - claywayExplorerThanks for the quick responses
Electric at pedestal good
Happened after unhooking & exercising generator
Anyway to “unstick transfer switch or is it shot - CA_TravelerExplorer III
Old-Biscuit wrote:
X2
Generator power output and shore power output go to transfer switch ,,,from transfer switch power goes to main AC Panel
Gen power OK
Shore power doesn't work..........TRANSFER Switch Stuck on GEN (Default)
Plus - Any power at the pedestal? Could also be plug/cord etc to the transfer switch. - Old-BiscuitExplorer IIIGenerator power output and shore power output go to transfer switch ,,,from transfer switch power goes to main AC Panel
Gen power OK
38,766 PostsLatest Activity: Jan 10, 2026
