avan
Oct 14, 2015Explorer
I had the same problem this summer. The fuse in the spot allocated for running lights was just fine so I figured it wasn't a fuse problem. After some time, I finally started checking all fuses both under the dash and hood. Turned out that there was a fuse in an 'unallocated' spot (per manuals), under the hood, that was blown. Replaced and voila, all worked. I've annotated my manual to now show that fuse box slot as "running lights". FWIW.
38,778 PostsLatest Activity: Jun 10, 2026
