mabynack
Oct 15, 2015Explorer II
fourthclassC wrote:
Update 10-14
Huge thanks to all who replied. I actually found a blown maxi fuse (20a) from a post that said it may be a fuse labeled in the ford manual as trailer parking lights. Not sure why it was labeled that because I thought Winnebago wired in the running lights. Any way I will replace the fuse and hope it dosen't blow again.. If it does more troubleshooting will be needed.
I was a diesel mechanic for many years and I would suggest that if the fuse blows again you might pull each of the clearance lights and look at the connections to the pigtails. The lights usually have a short piece of wire to connect them to the circuit and it's common for a wire nut to fall off and allow the connection to short. I usually put a wrap of electrical tape around the nut to keep it from vibrating off.
38,778 PostsLatest Activity: Jun 10, 2026
