Hey all- We have an '05 Holiday Rambler Ambassador. It had a Sanicon installed after market, I believe. The sanicon first stopped working about a year ago. The only thing I could see to replace was...
If you haven't cleaned the shaft of hair and other stuff, that could be part of the problem. Mine is a boxed unit I attach and use as needed, it has a fuse in the power line. While using the volt meter, did you have a good ground to work with, maybe need to chase the wires from one end to the other to find the power loss if there is no power to it.
