klipper849's avatar
klipper849
thetford sanicon system
I just went to camping world an was told there is no repair kit for thesaniconpump system anyone have any ideas,mine seems to be slowing down on pumping and makes a little noise once in while ,it is 6 yrs old.ed
  • Have you ever had it apart?....the motor should be taken apart and cleaned at least once every two years, more often if you or your camping partner(s) have long hair. Hair is the worst to get clogged in the blades. Simple process...take out the screws and pull it apart. Inspect the impeller (rubber) and clean the blades. Reassemble and you're good to go for another two years. The only fly in the ointment is the large gasket between the two body pieces. That gasket is pretty flimsy and is not sold individually. NAPA sells a roll of gasket material that you can make your own.....Dennis
  • When I contacted Sanicon on my unit they sent me just the gasket I needed. Might be worth seeing what they might be able to help with.
  • I think the grinder pump is made by flojet and they should have a repair kit for your unit.
Looking for advice before your next adventure? Look no further.25,192 PostsLatest Activity: Apr 15, 2026
