redT2go wrote:
Question from an electrical novice. If the house batteries are dead or defective, do they prevent the shore power from working? We have a 50A circuit on our house and the breaker seems fine. Plugged in power cord and got nothing. That has never happened before. Thanks for your help.
Generally NO.. However anything is possible.
Some RV's have a power manager. Made by Intelletec and I'm not sure if it needs 12 volt or not. HOWEVER even if it does the converter SHOULD supply and it should work.
I can think of a few possible issues.. I once had a bad plug connection on the Shore end of the cord. and a bad connection elsewhere in the system. Check the 50 amp mains in the RV as well.
I'm comfortable working on electrical circuits even live. but I do not recommend it.
Oh. True story: brand new (sticker in the window new) 5er. NO POWER said the wife after hubby plugged in.. Sure enough NO POWER.
Went to check if power was coming out the cord (The outlet end of the shore cord) Blasted MARINCO outlet fell off in my hand. Nobody tightened the half dozen screws inside.. I KID YOU NOT.
We fixed it.. But I'd have loved to be listening when the owner (an electrician by the way) returned to the Dealer...
