Anybody know how to quiet down my water pump? When the pump comes on it rattles the plumbing (really loud), Thor told me they put in a cheaper pump and to fix it I would have to put in a better qualit...
Before doing that...and this comes from experience...check at the inlet of the pump to see if you have a screen/filter gizmo, coming off the line>>> to the pump. If so, remove and clean, then see if that makes a difference. If not..then yeah, a pump change. You do it yourself and the pump is along about $75 or so. Shure-Flow.
