zac451
Apr 27, 2013Explorer
noisy water pump
Anybody know how to quiet down my water pump? When the pump comes on it rattles the plumbing (really loud), Thor told me they put in a cheaper pump and to fix it I would have to put in a better qualit...
Gene in NE wrote:When there is no water pressure, the tank is empty, regardless if orientation because it has a rubber bladder (like an inner tube) that remains pressurized. The rubber is seen tight against the screened opening of the tank at the fitting. There is no concern of water freezing inside. No plumbing pressure means no water, so don't worry about winterizing.
I was going to put in an accumulator tank, but could not figure out an easy way to keep from filling the tank with RV antifreeze when winterizing.
