zac451
Apr 27, 2013Explorer
noisy water pump
Anybody know how to quiet down my water pump? When the pump comes on it rattles the plumbing (really loud), Thor told me they put in a cheaper pump and to fix it I would have to put in a better qualit...
ron.dittmer wrote:Good answer Ron. Never gave it that much thought. I was associating the accumulator tank as being the same as the water heater. I forgot that after you pump the pink stuff in the pipes, if you open any one of the faucets the bladder will empty the tank for you.Gene in NE wrote:When there is no water pressure, the tank is empty, regardless if orientation because it has a rubber bladder (like an inner tube) that remains pressurized....
I was going to put in an accumulator tank, but could not figure out an easy way to keep from filling the tank with RV antifreeze when winterizing.
