RV_Dorothy's avatar
RV_Dorothy
non- working Dometic fridge
Our tenth RV is a 1981 Dodge Campervan, 350 motor automatic which has only 10,000 miles on it .
We bought it from a local who did tell that the fridge did not work on Electric , and we have yet to see if it works on Propane .
We have thought to tear out the whole fridge , as there are no signs of Ammonia stains or smell of Ammonia .
Has anyone experience in this ?
We thought it may have been parked wronto make this problem , and someonesuggested , taking the unit out and laying it on its side -how would you do this safely ?
  • Handbasket wrote:
    The typical small 3-way reefer used in class B's before about 2000 does not use 12V when working on propane. I've owned 2, and worked on another. They have a manual 'clicker' ignition, and use either a flame window or a needle gauge to indicate that they're lit. They're completely independent of 12V power, other than using it when set to 12V operation (heating element only).
    Jim, "Laughing stock: cattle with a sense of humor."
    I wish the newer ones had the manual, "clicker" override.
  • The typical small 3-way reefer used in class B's before about 2000 does not use 12V when working on propane. I've owned 2, and worked on another. They have a manual 'clicker' ignition, and use either a flame window or a needle gauge to indicate that they're lit. They're completely independent of 12V power, other than using it when set to 12V operation (heating element only).
  • Need good 12V DC power
    Open the outside compartment
    Clean it out with a shop vacuum
    Check that it is plugged into the 110V outlet
    Inspect for any signs of leaking (yellow powder/residue)
    Level the RV.......fridge operating off level WILL damage it. Flow is disrupted/overheats/creates blockage in cooling unit)
    Valve in propane
    Light off stove top burners on high to establish propane flow/allow LP regulator to function. With burners lit and steady turn fridge ON
    Select 'gas'
    If fridge temp control is adjustable turn it to coolest setting
    Wait 24 hrs and check that freezer is 0-10*F and food section is 35-40*F
    The not working on electric could be a bad heat element, bad fuse.
    Taking fridge out, turning it upside down is a band-aid fix to a clogged/blocked cooling unit. It will NOT cure the problem. IF cooling unit has blockage it is permanent!
    Find out IF it cools.
  • Why not try it on propane first to see if it works. If it does then you can diagnose the electric problem without removing the frig.
