By removing the norcold doors it was removed through the entrance door after removing the passenger seat. My refer is on the drivers side with a thin wall on the right side next to dinning table. Removed that wall as all it did was cover the unfinished refer side. Fabricated a platform of 1" angle iron bolt down through the floor. Installed a 23.5 cu.ft. Samsung side by side water and ice thru the door. Again removing the doors is required. Samsung does not require a pure sine wave inverter and does not void warranty by installing in RV. PM me if you would like more detailed installation info.
Blessings; Keith
