Old-Biscuit
Jul 09, 2016Explorer III
Norcold 1200 has 2 (TWO) elements......225W each
Need to replace both.
Can be done from lower vent opening
Unplug leads on control module......pull elements up out of sleeves.
May need to wiggle back/forth to loosen
Small access door held in place via a tab. Bend tab then squeeze housing to unlock tab from door slot. Lift door slightly up and then out.
