dougrainer
Jul 19, 2016Nomad
diplomatdon wrote:
Just a update on problem. Tried all the things mentioned as far as other appliances etc. causing problem. Not the issue. Tried new GFCI and not the problem. Would work if GFCI bypassed as Doug said, however the other plugs on the circuit not protected. We went away for a week, ran on LP. When we got home I checked the OHMS as Norcold Guy showed on his site. Resistance was within tolerance, put back together, plugged in and working fine. Guess it's good until the next time it happens. Don't know what the problem was but I claimed to the wife I fixed it. Thanks for every ones help and suggestions. Don
120 elements that trip GFCI will always OHM out correctly. One of the 2 elements is BAD, Period. I don't know who the Norcold Guy is, but I have 37 years of working on RV refers(always have fixed them). Doug
