dougrainer
Sep 04, 2016Nomad
TC&Z wrote:
When I looked down from the roof the top of the frig has 2 brackets tying it to the wall as well. The insect screen is molded into the plentum so only way to remove screws is cut opening in insect screen. Guess patch it up when done.
I would appreciate any references to sources and types of fans you mentioned.
There are NO brackets or screws that hold the refer from the TOP and accessed from the top roof vent. NOBODY does that. If by chance you have these brackets, someone else has installed them, NOT the OEM. The only screws are the inside 4 on the bottom and 4 on the top and 1 to 3 screws that are from the backside on the bottom metal plate. Doug
38,769 PostsLatest Activity: Apr 04, 2026
