dougrainer wrote:
I need to check for why we get water inside the fridge and many times, out onto the floor, so what might be the best way for accessing the drain pan system?
Odds are the check valve for the drain hose is gummed up. Outside look at the burner tube. Next to it is a black tray with the drain hose in it. Look at the end of the drain hose to see the plastic check valve. remove it and clean it out and reinstall. Doug
Thanks much and don't ask me why, dummy here hasn't noticed that hose and pan, with the many times I've been back there. I do know, without any doubt, that old age is hell, but then again, I'm still here, so that's something positive to say for it.
Anywaysssss.....I removed that little valve, if we should call it that and didn't think that the water was ever going to quit, with the way it was pouring out of there. Should be fine now and especially with the DW not having to put towels everywhere.
