tropical36 wrote:
It's always been a battle for keeping a NEVERCOLD fridge temp. under 40F, with the best of them, from the git go.
I can't imagine pulling the fridge for doing any kind of repair, without just doing an RC refrigeration conversion, while you're at it.
Choice of a compressor type or staying with the RV style is available, as well.
That's the only way, it's ever going to be right for proper cooling.
Once the refrigerant cell fails and it will eventually, you're done anyway and not to mention the possible fire safety concerns, that come with it.
It is not hard to get a Norcold down to 32 degrees and keep it there. MOST cooling problems are caused by BAD INSTALLATION by the Coach builder. AS to pulling the refer. From start to finish it takes me about 1 hour to partially pull and replace BOTH fans and the Fan tstat. I also run a 2 wire jumper from the sides of the fan tstat down behind by the rear control board to manually make the fans run by bypassing the fan tstst. This is for testing. Now, the Norcold Flat rate is 3.2 hours to do what I just detailed except for the 2 wire jumper. If you would follow some of the 1200/1210 threads you would see, once the RV'er gets the Rear of the Norcold baffled and installed correctly, the cooling is just fine. Doug
