MountainAir05 wrote:
Have you check out the heater for voltage and ohms (ensure it is not plug into power for the ohms check. page 38 looks like a good place to start.
http://bryantrv.com/docs2/docs/ncoldnnewnseries.pdf
Thanks.
Mine's a bit older. The AC power cord is soldered to the circuit board. I'll have to do a bit more searching to find the wiring diagram. Mine was still there, but the right side of it - where it shows the schematics for the AC heater and the door light (which doesn't work either) is worn.
