endeavour99
Jun 15, 2023Explorer
Update:
I used a 12v battery from my truck and hooked it up to the RV fridge and it worked perfectly in LP/GAS mode.
I again verified that I have 13.95 volts between the power and ground at the RV board, I then turned on the fridge and watched the voltage on the voltage meter and the power voltage went do to 7volts, while the fridge was sparking up... and then it through the A7. I ran a separate ground cable to the ground and no change.
I then ran the wire direct from the house battery to the fridge and the fridge works. I cannot find the fuse in either of my 3 fuse panels for the fridge. I even tried to short the positive and negative wires feeding the fridge and it didn't even have a spark let alone blow a fuse. Can anyone help with where the other end of this positive wire goes to? Which fuse box?
38,780 PostsLatest Activity: Jul 05, 2026
