dougrainer
Jun 16, 2023Nomad
Usually Monaco/HR, used the Left front outside storage for the large Circuit 12 volt panel and refer 12 volt power. They also used a 12 volt circuit breaker(5 amp) instead of a 12 volt ATC fuse for the refer 12 volt circuit. Unless after 25 years your printed label for ALL the circuits is gone, the schematic will tell you what circuits are there and their place on the large circuit fuse panel. Doug
Common causes of voltage drop in a 12 volt circuit when load is applied
1. LOOSE spades holding a ATC fuse
2. Loose nuts when on a 12 volt Circuit Breaker
3. BAD ATC fuse that the tungston has not fully blown and separated.
38,780 PostsLatest Activity: Jul 05, 2026
