endeavour99's avatar
endeavour99
Norcold 982 A7 when on LP GAS
Greetings All,
I have a 99 Holiday Rambler Endeavour with the Norcold 982IM.
After not using the RV for the last two years we had a slight mice infestation, but was able to get rid of them and repair the necessary wiring and hoses.
We got ready to use it, but the fridge started flashing A7 when on LP mode or if no shore power is available. It work perfectly on the inverter and shore power.
I opened the outside fridge compartment and verified all connections. I then removed all connections, removed the board cover and verified both (3amp and 5amp cylinder fuse) were good.
Finally I used the reset procedure to try and reset the board, by grounding pin 15 on the data connector to ground for 20seconds, but still getting A7 Low DC Voltage. Can anyone help?
  • How do you check the voltage at the refer? At the board I am getting 12.5v, but not sure how to check the voltage on the front of the fridge.
    When running or show power plugged in getting 13.5 volts at the board.
