dougrainer
Aug 22, 2018Nomad
Some OEM's use a small drip of silicone to hold the door panels in place to keep from moving slightly. IF this is the case, you have to use a metal flat piece of metal to slide between the door panel and the door backer to cut that silicone loose. Doug
