paulsang wrote:
Hello my fellow Class A drivers! I searched for this issue in the forums, and nothing came up, and I hope someone can help.
Today, we are setting up to hit the road Thursday. I tuned on the norcold, and it is beeping, and flashing 'no co'.
It is already cooling given it has been about 6 hours since I've turned on.
The manual says to turn it off, and refer to manual. That's it. Crazy.
Any input?
Thanks!
PAul
go to the rear and remove Vent cover and see if the red lite is lit up on the small black box (Recall system) If it is either the cooling unit has failed or the recall sensor has tripped.A schooled Norcold tech should be able to figure out which it is
